Perfect! Thanks!nope, use the original nut.
You can't use the washer it won't allow the nut to fit. Also, I think the stock nut will scratch the numbers off (or maybe that was the stock washer) - make sure you check that.Perfect! Thanks!
PS, do you still use the stock washer behind the Castle nut?
https://tstindustries.com/Gilles-Tooling-Rear-Axle-Nut.html
The manufacture also makes anodized aluminum nuts just like the one above.
Yeah it is pretty cool, very happy with it, but for 90 bucks plus the cost of those chain adjusters (in total over 300 dollars), it's a pretty expensive mod that frankly I wish I didn't do, and used the money elsewhere.Wow, that titanium nut is triiiiick! So cool!
I like this from PRo-Bolt, but can't tell if it locks???Check out pro-bolt. They've got like every nut/bolt imaginable for these bikes. Titanium, Aluminum, Steel... you name it... the got it.
They've got some sweet colors too.
Titanium, Stainless Steel, Aluminium Fasteners & Motorcycle Bolts | ProBolt
That one is a little fancy. Here is a "vehicle specific one" (which has cotter pin slots).I like this from PRo-Bolt, but can't tell if it locks???
https://www.pro-bolt.com/titanium-axle-nut-rear-wheel-93.html
I assume you talked to a salesman who doesn't know what you're talking about haha. That's for a swingarm front axle nut. Totally different specs.Pr-Bolt just replied to my inquiry and said mine should be an M20 ???
https://www.pro-bolt.com/titanium-axle-nut-swingarm-86.html
Thanks for confirming...'cause that is what I ordered!I assume you talked to a salesman who doesn't know what you're talking about haha. That's for a swingarm front axle nut. Totally different specs.
OEM rear axle nut: 32mm socket, 24mm thread dia, 1.5mm thread pitch
ProBolt rear axle nut: 32mm socket, 24mm thread dia.. and so on.
Titanium Axle Nut Rear Wheel
I checked the Microfiche, and the Gen5 rear axle castle nut is listed as an M24I've got the pro-bolt axle nut and a few other goodies myself. The one I linked is the one I bought. Perfect fit!
Or as Cycle Cruiser says: JUST LIKE OEM!!! (1,000 times)
If my bike wasn't at the tuners right now I would be able to show off the swag :lol:
