Light Werkes LED taillights integrate a brake light and turn signal function all into one. This is especially nice for those of you that want to eliminate the bulky rear fender yet wish to retain functional turn signals without having to cut into any of the bodywork. This simple to install LED system includes a direct plug in harness for brake light functionality though, for some applications, you will need to splice some wires for the turn signals to work.
Available for 2006-2007 Kawasaki ZX10R
We have these available with either a clear or smoke lens. Give TJ a call at 866.931.6644 ext 817 to get yours shipped out today. You can also send your questions to FORUM at RIDERSDISCOUNT dot COM with LIGHT WERKES in the subject line along with the model and year of your motorcycle and we'll get back to you right away.
Clear LED taillight kit.
Smoke LED taillight kit.
Bright LEDs won’t burn out – so you don’t have to worry about ever replacing a bulb. They’re also quite a lot more visible than a standard light bulb.
Wiring harness.
