Cheap is good! That floor looks fine. I like the checkered look too.
What kind of ramp is that? I have the double doors in the rear also.
I may need to make a trip to Pitbull and see about that wheel choke. That would be nice to have.
I have plenty of 110vac lights. I'm going to look for some low wattage 12vdc lights to run off a spare battery.
That reminds me, How bout some awesome 12V LEDS in there. Some of the brighter ones give off plenty of light and they draw very little current even for a whole row of them.
The ramp is a homemade contraption that is removable. And hinges on a rod I slide in at the base of the doors that I can remove if I want. When in place, the ramp folds up in the trailer, too. It's a good idea, but looks pretty hideous. :badteeth:
It's made with steel tubes, plates and angles from Home Depot and my cheap old hundred dollar wirefeed welder. 3/4" wood plywood for the flooring. When you don't have the money, you improvise.
Pitbull restraint system is OK. Mainly looks cool. Requires you to get the bike straight in to lock it down. But a good wheel chock is somewhat easier to use.
