1 - 20 of 22 Posts
Hey guys
I've just installed a set of AuxBeam F-16 plus LED bulbs on my gen 5.. the difference was night and day.
Had to do quite a bit of work to get it to function properly.
1. The Auxbeam came with a driver box. Since it wouldn't go in the housing through the access panel i had to remove the front lenses and stuck it to the side of the reflector.
All the wiring was tucked in the housing.
2. The bulb has a fan on the end and pulls air into to housing. So i drilled a hole (even though there was enough clearance to put the cap on without modification) and made a sort of funnel to keep the rain out.
3. Lined up the low beams to standard and I lowered the high beam to where it can be used at night without blinding oncoming traffic.
Will keep you guys posted on the long term performance of this mod.
That is nice. I did something similar on both the high and low beam and I used rubber covers instead of using the original cover. The rubber covers fit but they are not waterproof if I get caught in a heavy downpour. I liked your idea and will order the OEM covers to modify those. I used the Katana bulb because I had good luck with those. I used them on my truck as well.
I'm not gonna lie and say that's cool. That is not the proper install just to have the magical LED headlight bulbs. Putting a funnel on back of the covers still exposes the headlight reflector to atmosphere. Water, condensation, etc. still can get right in there. Especially with the fan pulling air in through the funnel and all that tire spray kicked up from the front in the rain. And I hope you intend to check for bug carcasses in the headlight periodically. Having to disassemble and put the driver unit into the reflector housing is that much more problematic and hard to secure. While I applaud your DIY approach, these fan-cooled LED lights have no business near these bikes IMO. If you're happy with it though.
There simply are no plug-n-play LED headlights. The closest thing would be the GTRLighting CSP mini. The aluminum heatsink will fit the reflector, but the OEM plug connector is too long for the cover to go back on. There has to be a right-angle pigtail used to get power to it to allow the cover to go back on without interfering with the spades. But these use the Philips Lumiled LED chips and would be the closest that I can find to be even remotely usable the proper way.
sky: that is very good information and agree with your assessment. The best upgrade that I did on my CBR was the HID kit retrofit mod. now there is a company that supplies HID replacement headlight assembly for around $600. I may go that route but I dont do a whole lot of night riding so hard to justify. I know how to retrofit HIDs projectors and waiting for a headlight assembly for sale for Gen 5.
If you're looking for more light at night, then the HID would be the better way to go for sure. If you're looking for more of a color change to help with visibility during the day, then LED would be an option along with the HID in the current reflector. Although the HID has more options for color temp than a lot of these LEDs. The ones I posted above are only available in 6000k so they'll have a tint of blue in them. I prefer the 5000k color temp for pure white. People typically shy away from the HID because of the igniter module. Mounting that has the same issues as the fan-cooled LED one above. The igniter is bigger so it has to be mounted external to the housing. Plus, the wiring has to go through a grommet to the bulb. Projectors are a whole other level. They are sharp and provide good focus. If you're going that route, then go for it! Most people won't spend that much for the lights though and are looking for a cheap bulb to just slap in the headlight for "more light".
I would consider the LED I posted before for a use in my bike for daytime use. But I ride around with the highbeams on all the time when the sun is up. I have HID bulbs already that I just haven't fitted yet. I don't like the placement options for the igniter that I can find. I may get bored and test out those CSP minis when I get the chance. But that would be only to change the color test away from the halogen to add some visibility. We'll see. I wouldn't use those Auxbeam CREE ones in the fog lights of my truck. :sneaky:
The retrofit Project mods that I did was quite involved. Luckily, I had a spare headlight assembly that I modified to install projectors. The retrofit HID kit was specially made for my CBR. The ignitors were slim. The Kit had halo and angel eyes so lots of wire to work with. I was able to tuck them below the assembly on that bike (2012 CBR). I did several highway night rides and was pleased with the results. I may go that route if I get my hands on a headlight assembly. The other option is replacing the one with already made one. I will look into the bulbs you mentioned a bit more closely. I used the Katana bulbs because they are also on my truck (Nissan Frontier) for three years now and provide very good light.
I purchased a set of LEDs for my '17, plug and play with the factory dust cap, they are out there.
These types of bulbs are available. I'm assuming something like this is the type you bought for it. They are shit.
Don't fool yourself. Just because they say "headlight bulb" on the packaging doesn't mean they are the type that can be effectively used in a headlight housing designed around halogen bulbs. The mirrored headlight reflector inside is designed around light source. A halogen bulb has a filament the size of a single grain of rice. You can't slap these types of bulbs in there with a light source this big and expect to get any sort of good illumination from them. This type should be used in a flashlight or a foglight. Or a headlight originally designed for LEDs with more of a projector lens. None of which the ZX-10R has.
There are viable options out there, but none of the ones that I have seen qualify as "plug-n-play". The design of them has to mimic the focal point and light dispersion pattern of the halogen it's replacing. In order to do that, it will produce heat and will require a heatsink to not damage the LED chips on them. The heatsink and assoicated wiring to drive the higher power is what the issue is with fitting them in the housing of this bike with the covers.
  • Like
Reactions: MSK1959
SKY, have you had a chance to install HID on your bike yet? If so please post your experience. The LEDs I have are so so at night.
Nope, I haven't played around with my HID set yet. I have a set of LEDs in there right now that I have played with a little bit. I primarily ride during the day and the few times I've been caught after dark, the light output was similar to the halogens. I wasn't disappointed in them, but I don't really care about more light output really. My main concern is the visibility during daytime to be more visible to other traffic which has more to do with the color temp of them. More illumination at night has to do more with the reflectors in there than it does with the bulbs. Especially since only one side operates for the lowbeam.
Thanks, SKY. On Amazon, a Chinese company is selling the entire headlight assembly they claim to be 300 times brighter than the stock for $549 and free shipping. It is expensive but tempting. Also as I understand it removing the stock headlight is quite involved. I have only seen one video but have not done it myself. The traffic here in Tulsa is quite decent in general with occasional cagers on their cell phones, but I have been noticing that they do not pay attention to motorcycles.
That's interesting. I always question what people mean when they say "brighter". The bulb is what produces the light at a specific brightness. The reflector is only there to focus the light. So if they are claiming the reflector itself is "brighter", all they mean is that it is focusing the light pattern to direct the beam to a specific spot instead of scattering it around. For the lowbeam, that would mean more light on the road to see what is ahead of you with a smaller, tighter focus point. If that's what you're looking for, then it would may work. If you're looking for more light over a larger area, then it's not.
Removing the headlights isn't that bad. You have to take the whole upper fairing off and then just unbolt the reflector housing. Hard to get to screws and a bunch of wires is all. But it's not that bad if you have removed the fairings before.
My 2004 Honda CBR was not bad. 2012 was the worst as it had loops and was a pain to get those back on. I have not messed with this ZX yet but I am sure it can be done. I agree. In terms of what I am looking for is for brightness: to be able to see the road better at night at highway speeds. Some Oklahoma highways and Tulsa Streets are not the best in the Country despite most highways are toll roads.
LOL. Here is the link. It says 300% brighter; I agree with your assessment.
Yup, seen that before. It's basically just a projector-beam headlight assembly. The "300% brightness" claim is marketing lingo. It's brighter where the light is focused, not overall. It's the difference between a floodlight and a flashlight type of thing.
Have you ever tried adjusting the angle of the current housing to raise the light beam up so you can see a bit farther out at night? The adjustments are on there to adjust for the beam angle. Raise it up some and see if that's better for your needs.
No, I have not adjusted it yet. This evening I plan on doing that to see. The high beam is too high and throws the light onto oncoming traffic and the low beam is too low.
1 - 20 of 22 Posts
