I guess I will have to start experimenting.
Off :crackup:
Meh, I regularly stomped guys using LC last year off the line. 2-3 bike lengths worth before turn one. I'm better without it. If you were closerNo turning it OFF in the Woolich Launch Control system, which works perfect on my bike. You just choose to use it or not.
Any one thinking they are beating me thru an intersection at a stop sign or traffic light is sadly mistaken. :thefinger_red:
Like being launched out of a cannon and you better be hanging on tight with the "full death grip" when the ramp speed releases at full throttle. :crackup:
Hold the throttle wide open, dump the clutch and hang on and the electronics handle it, for a bit, a very short bit, then you better be waiting for the flip over to occur so most people just feather the clutch which defeats the purpose. :badteeth:
Dump it!!!
You already lost the bet about the block off plates in another thread, :crackup:Meh, I regularly stomped guys using LC last year off the line. 2-3 bike lengths worth before turn one. I'm better without it. If you were closer
I'd take that bet.
Do you have any recommendations on settings besides baseline? Is there a easy way to activate it? I just don't want to mess up at the start like Nike did just trying to get it to activate.The LC is nice. Doing drag nights (puke) are a good easy (legal) way to test. Especially if you have a log box. You can monitor your times with the slips you get at the end of the run which is good, but you can also go back and look at the data in data viewer in Woolich. "Oh I made this change to the hold time parameter and I did 0-80 in 3.7 seconds as opposed to 4.0 last time". You get an idea of the changes you make and how they are positively or negatively effecting your launches. Come next time to grid up, you've got it dialed in and can easily make up 4-5 spots.
This is the problem with most Track guys by that I mean competition on a Road Course most stay away from the Drag Strip it's beneath some of them to try so Like Archer said even though he is not a track guy that's how your going to get faster and why most drag racers know they will have no problem launching against Track guys, so just guessing they just don't take the time to do test and tune days at the drag strip like the Drag Racers do.Do you have any recommendations on settings besides baseline? Is there a easy way to activate it? I just don't want to mess up at the start like Nike did just trying to get it to activate.
Launch Delay: This is the amount of time the clutch has to be pulled in before the launch control kicks in.Can someone give a "explain like I am 5" explanation of the "Ramp Start Vehicle Speed" setting.
is this for a gen4 with the Woolich flash or a gen 5..or both??Hold the throttle wide open, dump the clutch and hang on and the electronics handle it, for a bit, a very short bit, then you better be waiting for the flip over to occur so most people just feather the clutch which defeats the purpose. :badteeth:
Dump it!!!
