OK, this is the last time that I will post a question about the Sub Throttle Sensor. I have just checked the Resistance on mine after receiving some readings from another member on this site. The readings he gave me were very slightly different between the factory position and fully forward position. The factory setting says that the readings should be between 4 - 6K ohms. His readings were 4.08K ohms in factory position and 4.63K ohms when moved forward. Mine was reading 5.23K ohms in factory position and 5.23K ohms when moved forward = NO difference. The question is IS THIS RIGHT. Can anyone with electrical background tell me if this is correct that the readings should be the same.
Thanks in Advance
coach.
