1 - 13 of 13 Posts
Hey dudes,what to do when a larger diameter rear tire (208gpa) hits the rear fender? Did a search and nothin came up? :dontknow:
Washers between the fender and swingarm I heard, I had them leave my 520 convertion chain a little long so my wheel is all the way back.
Hillbillie Mod
:+1:
that and buy a new chain to skoot the tire back.
just use some washers as spacers and you can keep it on.
Take the fender off. Or spacer it up some. As far as chain lengths go, you start affecting your suspension setups. Example, I used a longer chain for damp/wet tracks ie you are lengthening the wheel base by just a little.
Hillbillie Mod
well if we're gonna go there...
the larger tire takes away from the swing arm angle so addin a link or two actually just gets things back to normal! :wink:
Yep I have the same problem with my 208gps. But Im not about to spend 200 bucks on carbon fiber one from OPP...:badteeth: I'm going to go with extra washers when I run my GP's
Discussion Starter #11
:iamwithst
Hillbillie Mod
also, hotbodies is commin out with one...dunno the difference...on their site its 179msrp.
1 - 13 of 13 Posts
