I have a KIT ECU fitted to my bike a few days ago, but ran into a few problems while trying to adjust the stock (actually empty) fuel maps to have some not-that-weird AFR curves.
A good friend of mine is running a local DynoJet tuning shop, so he has some knowledge about tuning bikes like this, but unfortunately not much (okay, I think actually ZERO!) people have knowledge about the KIT ECU tuning here at Hungary. We tried to do our best, but I am still not satisfied with the results, so I am here to ask some help.
The best docs I could find about KIT ECU and tuning was the following: Kawasaki KRT kit ecu tuning Factory Pro
Unfortunately it was written for an older bike, not having ETV, IMU, TC, and all that fancy hardware...
I know that tuning the 2016 ZX-10R KIT ECU might be a bit tricky because the ETV opening might differ from the actual throttle grip position. To overcome this situation, we tried to use the built-in logging feature of the KIT software, so we had some information about actual ETV opening on the lower rev. ranges before the ETV actually matches the actual grip position.
Attached the fueling map that is currently on the bike for "Comp. Map for Injection #1, #4". The compensation map for injector #2, #3 are the exact same.
The other picture is the output of a WOT (100% throttle all the way) pull with actual AFR measurement.
My biggest concert is about those rich spots around 6000-7500rpm and 8500-10000rpm. A decent amount of fuel (around -10 to -15) has been removed already, as you can see in the maps. Should we pull a little more, or there is something we are doing wrong? :dontknow:
