1 - 4 of 4 Posts
I have been running Goodridge Kevlar lines on my 05 for the past 3 years. I just switched over to SS lines and i can say that the lever is defiantly stiffer.
Also on both sets i ran both lines from the master cylinder directly to each caliper and got rid of the stock cross over line.
So if you ever think about kevlar its not worth the cost. it is stiffer than stock but not as stiff as SS lines at the lever.
The kevlar lines are also pretty easy to damage.
SO Go for Stainless steel braided over Kevlar.
Licensed Dist of HaterAde
IF there is it's probably a matter of a couple grams/ounces max....but i know it all adds up in the end right?
1 - 4 of 4 Posts
