1 - 7 of 7 Posts
2016 Kawasaki ZX-10R KRT ABS Edition
help, removed the headlamp, after removing the headlamp, I found a rubber tube, I can’t find its place now, if you know help
That goes to an actuator for the charcoal canister. That entire canister can be removed, so no big deal. Search "emissions removal" or similar and you should find some tutorials with pics on here to help you figure things out if you're still lost.
Will this require a flash to clear the code when this is disconnected?
I don't believe so. Just unplug actuator thing and see if it throws a code. If it doesn't you're good to go.
Looks like it's that blue plug below the canister you want to unplug and see.
Gonna have to flash it out then if you want to remove the whole thing.
1 - 7 of 7 Posts
