1 - 3 of 3 Posts
Hello guys, I bought a new exhaust AustinRacing v3, and I bought a Servo body, but I make a mistake, I turn my bike without exhgaust and have a gave an error like on a foto. This is a mistake in a system and in engine
This is instruction
"IMPORTANT:Install the Servo Buddy before turning your bike on to avoid a stored fault code"
Please, help me, and say what I can do decide this problem at home, if it possible, because there will be a problem to go on official service.
I'm not sure what you are thinking here. Anyway go to the auto parts store and purchase a code scanner tool. Then order the KDS adaptor for the tool from FTECU. Plug it in a read / clear the code.
Then if the servo buddy works as described all will be good.
Really the best option is to ditch the servo buddy and purchase the Ftecu flashing kit and all the problems will be solved
2016 Kawasaki ZX-10R KRT ABS Edition
There's plenty of tutorials on YouTube on how to do a hard-reset to get rid of the dash error. Worst case scenario, if the hard-reset doesn't work, then you're going to have to either flash the error out of manually clear it with an OBDII sensor and the proper Kawasaki adapter.
1 - 3 of 3 Posts
