1 - 3 of 3 Posts
A friend of mine recently went to our local Kawi dealer to purchase an oil filter for his ZX6R (05) which uses the same oil filter as the ZX10R's. Anyhow, he was given the ZX14 oil filter, and was told that the old part no. is discontinued and according to Kawi, the ZX14 part supercedes it.
Now the problem is the ZX14 is about 1/4 inch taller which means clearance problems if you have a full system. If this is the case it means our only choice will be aftermarket filters.
They changed the internal element and got rid of the metal cage inside the filter. If you are worried about the height of the filter the Honda ones are exactly the same as the newer Kawi filters but are about 3/4 " shorter.
good call... the Honda cbr's and Kaw zx's take the same K&N KN204 filter.
1 - 3 of 3 Posts
