1 - 2 of 2 Posts
The job of your motorcycle’s air filter is to provide clean air that is free of dust and other particulate matter to the combustion chamber. Doing this in a manner that is both, efficient for maximum power delivery and safe for your engine is not easy. K&N air filters, through continued research and development, strike a balance between these two properties: often providing a noticeable increase in intake performance while at the same time protecting internal engine components. This is done using a high-quality cotton that is kneaded, woven and layered in a very precise manner which is then oiled to trap dirt and dust with 95%-99% efficiency. The distinctive reddish filter elements are surrounded by a hard urethane and plastisol chassis providing a positive, leak-free fit for maximum engine protection. In addition to these protective properties, K&N air filters are washable and re-usable – there is even a kit available for refreshing your air filter after a few thousand miles of use.
K&N air filters are available for most late-model motorcycles. To order yours, call Mike at 866.931.6644 ext 804. You can also email us with any questions you have – send those to FORUM at RIDERSDISCOUNT dot COM with K&N MOTORCYCLE AIR FILTERS in the subject line and please be sure to specify the model and year of your motorcycle for accurate availability.
K&N air filter for Kawasaki Ninja ZX10R.
Discussion Starter · #2 ·
Air Filter Maintenance and Replacement
Have you taken a look inside your motorcycle's airbox lately? Now that we're more than halfway through the riding season (in the northern part of the country, anyway!), miles' worth of crud has made its way into the airbox. We've found everything from insects and leaves to road rubber, sand and even small stones in our bikes' air filters. And that's just what you can easily see! Upon closer examination, you'll find that there's smaller debris stuck in the filter element, especially in the crevices and around the edges, all of which is detrimental to engine performance.
Now, for those of you that have already upgraded with a K & N aftermarket air filter, we can supply a K & N filter cleaning kit so you can easily replenish your filter for like-new performance. Those of you with an OEM air filter, now is the time to upgrade. We have K & N filters available for just about every make and model, call us today and we'll get you a brand new K&N air filter shipped out fast!
1 - 2 of 2 Posts
