1 - 6 of 6 Posts
I have taken it apart 3 times to check the TPS wires, and they are plugged in tight.
I have loaded a few different maps, and the bike generally revs good (on stands) but it will not idle. When I try to let it idle, it dies but I can rev it to keep it alive.
I dont think its a map issue -maybe a wire problem or I damaged my TPS???
Any thoughts?
I searched around for a while and found a old thread about the "rough idle update" but I dont think it applies b/c the post was back in 04.
ANd I didnt see anything on pc website about this...
Thanks,
Andrew
Rent this space
Did you reset the TPS with the PC111 ?
Also dif you get the PC111 connected to the right plug, it is easy to get it wrong, as the grey and the brown plug are the same.
did a search and was able to reset the TPS.
I also, cleaned out the connectors really well- nd the bike idled normal...
I dont know which it was but im happy...
THANKS!!
1 - 6 of 6 Posts
