1 - 20 of 26 Posts
i have just bought a micron serpent full system from ebay very cheap.
i have the 04 model, what do you guys think, how much hp would i gain? i also have installed a pc3 usb and a KN air filter. is the map from the dynojet website good or i should make a custom one? thanks
T Double D
i dont know but put it on a dyno id love to know
Nice, I've got the Micron GP Sidewinder on my 08 and absolutely love it!!!
Discussion Starter · #6 ·
i did not received it yet... i'm just searching for any information about it...
even a custom map....?
Dont mess wit White Ninja
Don't download a map!! Get your exhaust in the first place then take it to a tuner and have a map made!! If you want every ounce of power out of your bike you will hit up the dyno for a map if not try your best to find something similar which shouldn't be that hard. But keep in mind who or where ever this map came from the conditions of the map may not work compared to the conditions of your area like humidity/elevation etc. I recommend a custom map hands down.
Discussion Starter · #8 ·
i guess you are correct, i will load the dynojet map and then go to a tuner and do the job!
You could get a Vance and Hines FuelPak, then go onto their website and get the settings for it.
Discussion Starter · #10 ·
came today, already installed in 2 hours and 20 min by me alone.
in a couple of hours i will load the map and if i go for a ride i will tell you all
about it!
Discussion Starter · #12 ·
went for a smooth ride and all i can say is that i have more power in all the rpm band....i have loaded the dynojet website custom map and it seems to work very well and smooth.
tomorrow i will go for a dyno test and i will tell you all about it....
Discussion Starter · #15 ·
well just came from my mechanic, the dyno run was made on a dynojet dynamometer, you know what i have on my bike.....
the result was 163 bhp in the rear wheel.
remember that the map i had on the pc3 was from the dynojet website.
my mechanic said that if we make a custom map i would gain another 3-4 hp.
but from the graph it shows that its a good map.
i found some other dynoruns on the net that where about 160-165 hp so i think its ok..
what do you think?
Discussion Starter · #17 ·
forgot to mention that the redline was 13800 rpm...!!!!!!
to tell you the truth i never! had noticed!
:ttiwwop:
1 - 20 of 26 Posts
