Locate the four pin black connector behind battery (Fig
7). Remove male connector. While holding the male
connector with release tab up and the yellow inserts
facing you. Remove the lower left yellow insert and the
upper right yellow insert. Insert jumper
wire into the previous mentioned open sockets until you
hear a click. (Fig 8) The black jumper wire should jump the
light green with dark green tracer wire and the black with
yellow tracer wire on the female socket (Fig 9). Plug back
into female connector.
makes stock ecu go to second map that seems to have better ing and fuel curve with speed restictions removed.
enjoy
Dave T
enjoy
Dave T
