1 - 5 of 5 Posts
General question: Is jetting necessary for the 10r? I've just purchased a Yoshi TRS slipon and was considering getting a power commander. However, I was wondering if I purchased the power commander, would jetting be necessary or does the power commander substitute? Any help would be appreciated as this may be a dumb question for those experienced.
Still here
Jetting is for carbs and this bike is fuel injected so the power commander IS the "jetting."
The 10r is FI or fuel injected if you will so no rejetting (technically) speaking but yes a PC or power commander is whats used to adjust the air/fuel ratio with whats called a 'map' programmed/loaded into the PC for those adding aftermarket exhaust, filters, cams, etc.
1 - 5 of 5 Posts
