1 - 14 of 14 Posts
please help me about,...
what ivans tre does?
open the servo butterfly ?
i have always open the butterfly - i dont have lines....
i have acrapovic slip on-k&n filter and pcIII custom map...
is the ivans tre good for me? what difference i will see?
i need power on the top ..... 10.000-14.000 2nd-6th gear
sorry for my pour english
If you're looking for an increase in hp, the TRE isn't for you. On the GEN1 bikes all the TRE does is make the throttle on/off transitions smoother by eliminating the fuel cutoff when you close the throttle going into a turn.
want to run a cbr1000rr '09 ...
before he win with 5 meters distance.. we run with 2th gear in 6.000 prm until 6h gear.... 1mile about...
i have acropovic slipon and custom pcIII map....
what else to do to be winner?
the tre will not help?
dimitri i ran yesterday a cbr like that and he lose for 10meters distance
we ran with 2nd gear in 8000rpm until 6th gear ... 800meters about
i have acrapovic slipon without pcIII
stock gear
195/55 rear tire
i have a tre for u if u want but i think that ll help u much more if u run ur bike without pcIII
Late Apex
will the tre eliminate the backfire burble when you close the throttle lol
Newfie Bullet
pc3 with a map and a slip on will do way more than tre..
Discussion Starter #12
K&N or DNA (i see you are from Greece, so support the Greek products).
Change your gearing to 16 - 40 (-1 front)
And, by the way, the 04 - 05 10's have their rev limiter kicking in 12750 rpm, so no gains at 14000 rpm are possible :wink: .
you say to change the gears at 12750? i keep them until 13.500...
with 16t sprocket i am loosing power to the top end -- i have try it
I say you can't be changing gears at 13500, because the rev limiter kicks in at 12750 rpm - maybe you are fooled by the factory error to think that you're changing at 13500.
With a 16t you can't loose power. The bike will rev faster - although your speed at the rev limiter will be somewhat (not much) smaller than the 17t - 40t.
Discussion Starter #14
ok understand what you say...
to the gauges its defference the rpm from the realy
1 - 14 of 14 Posts
