1 - 9 of 9 Posts
Today I used the TRE of the IBAN, but the FI lights on
According to the damage the sensor speed is fault
Does anyone know what s going wrong??
at the GPS connector i choose the black and the green with red stripes wires
Here are the instructions for Ivan's:
1) Remove fuel tank & airbox
2) Locate GPS connector at bottom of fuel rail on left (green 4 wire connector) and release from fuel rail. (you will need to depress the release tang)
3) Separate connector and remove the 2 wires (green w/red stripe and black) from the female end of the connector (the end with the male pins)
You will need a sharp pointed implement to depress the latches that hold the pins into the connector.
4) Install the pins that were removed from the stock connector into the supplied connector.
a) When installed correctly, you will hear a click when they seat.
b) Pay attention to their orientation as they will only fit when in the proper position.
(if you force them they will get damaged)
c) It does not matter which side of our connector the green/red or black wires are installed on.
1 - 9 of 9 Posts
