1 - 3 of 3 Posts
Ok i have a 2005 ZX10R and its got around 8k on it and it wont crank up, it turns over and will shoot flames out of the exhaust, all the fuses are good, i just replaced the spark plugs less than a thousand miles ago because the fouled out very badly, i think that is way to early for the spark plugs to foul out, i have a power comander, intake and slip on exhaust, the bike has aleways ran good just one day i went to got crank it up and let it run for a little sense im not riding it a bunch on the count of its cold as crude outside and it kinda missed for a minute and then smoothed out, later that night i went to crank it up again to see if it did it again and it just turns over and ccasionally shoots flames. If anyone has any ideas whats going on it would love to know what you think.
Still here
First thing to do is remove the power commander or try resetting it first.
If you went to a shop, removing the PC from the loop is the first thing they will do.
And yes, 8k is way early to HAVE to replace plugs.
1 - 3 of 3 Posts
