1 - 10 of 10 Posts
Hi guys,
Can any1 help me out, what parts are interchangeable with the models in the title please!?! Anything at all
Thanks lee
Not many parts are interchangeable for these. Are you looking for anything in particular to swap over from a 2nd Gen to your 3rd Gen?
I know for a fact that the heads from a Gen 3 will fit a Gen 2 and vice-versa I believe.
I know there was one member who fitted a Gen 3 head on his Gen 2 and it makes good if not better power than before with the original Gen 2 head.
Discussion Starter · #3 ·
I’m wanting to put gen 3 throttle bodies on my gen2 superbike engine, thanks for the help ??
Yes mate your G3 throttle Bodies will physically fit onto your G2 engine, but as you know the G3 throttle bodies are designed to work with secondary injectors in the airbox so the lower injectors are different to G2 injectors (smaller) as long as your plugging in the G3 bodies to a G3 harness with appropriate ECU stock or KIT youll have no problems but better response & delivery once mapped in. The G2 motor slots right in the G3 frame no problems.
This is great to know.. I have a 07 zx10r I would like to upgrade my front braking system.
Pretty sure Gen3 brakes are not a direct swap. Most people use Nissan calipers off of a 14R or 6R of certain years which I'm not sure of. A quick search should set you right for that mod.
Sent from my XT1045 using Tapatalk
Oh ok. Sounds like a plan with the front calipers I will check and hopefully find a idea. thanks
1 - 10 of 10 Posts
