I installed my vortex rearsets on my 06 zx-10r today and I had a problem with the shift lever hitting the spring on the kickstand. Has anyone else has this problem? I know there are a couple of people on here who have installed vortex rearsets on their 06's. It would hit the spring no matter how high or low I went with it. I flipped the spring around to give it a little more clearance but that did not help. I just put a hose clamp on the spring to keep it close to the kickstand till I can find another solution. Here is a pic of the problem.
Had satos on my 04 and the quality is pretty close. Vortex makes really nice stuff, except for their rear sprockets. I went with the vortex rearsets because they had more adjusting points than the satos and all any other than I found and I need that because the 06 has the pegs moved up and it cramps my knees. I am 6'5" and the vortex rearsets put me in a nice comfortable position. I actually like the feel of the vortex pegs better than the sato pegs, much more grip on the vortex pegs.
I remembered you saying that at bike nite last nite thats why I was bustin' on ya:mrgreen: that spring fix looks to be a bit of a poser hopefully it will be an easy fix good luck on that:thumbsup:
What's up Trey. I didn't look at the name, but I am a little intoxicated so it's expected:beer: . I will probably drill and tap the backside of the kickstand and move the spring there, hopefully that will work.
That's were it is comfortable for me. You have to remember that I am a tall guy and that really effects the angle that I need the shifter at. My legs are at much more of an angle than someone who is shorter. If it were any higher I would have to lift my foot off of the peg to shift and that would not be good.
Didn't make any difference. I had them on the right way and it still hit when I put them at the lowest two positions. All you guys are showing me pics of 04/05's and they are not the same. When I talked to vortex the other day they told me that you could swap the brackets to give a little more leg room so that's what I did. I tried to call them yesterday but they were closed when I called. In almost any position the spring touches the shifter if I did not have the clamp holding tight to the kickstand.
yea a very severe downward angle for sure but if thats the best position so be it, however it doesn't look like vortex accounted for this when doing R&D.
uhhh another good thing to do is go to your local bike salvage yard and try different shift rods. my shift rod after installing my quick shifter had to be slightly bent... alittle curve in it and now it works great... hope that helps.
Ok so I should put it higher and not be able to shift? I am almost 6'6" tall and I wear a size 13 shoe. I put the thing where I can reach it without lifting my foot to downshift. Read the thread people.
That was pretty good. Whish I could and I wish I was smaller somtimes becasue it would be so much more fun to ride if I was 5'10". At least I don't weigh 280lbs, that would really slow the bike down.
I have annoying problem with the KQS.
Going up 3rd is near impossible to get other than the first two laps.
It was the same with the stock pegs, is the same with rearsets.
The bike had the recall for the suspect gear and I feel the KQS to 3rd got worse after that, although it did more track work...
I'm starting to build up a new motor for my G1 track bike. I have gathered a clean core motor (28k, almost all highway commuter miles, great compression), G1 kit intake cam, and a few other items. I tore the motor down yesterday to send the head out for a clean/beadblast/mill/port/rebuild and...
Tech question. Bike stalled on me the other day when I was rolling up to a stop sign with the clutch pulled in. Now when I try starting the bike in first with the clutch pulled in the bike moves forward. Like the clutch isn’t disengaging. I have proper 3mm clutch lever free play. Took the cover...
Hi There, I’m in NewZealand and race an Open Wheel Lightning Sprint, have just installed a 2008 zx10r. Had an ECU flash done then onto dyno for tuning, for some reason a sensor is telling it that it needs more fuel than necessary, fuel pressure set at 43psi but far too rich, went as low as 28psi...
If a gen 4 throttle body, wire harness and ECU are installed on a gen 5 engine, will a gen 4 gear position sensor work properly on the gen 5 engine? I've read that a gen 4 gearbox can be installed in a gen 5 engine and then the gen 4 gear position sensor will work. I'm wondering if the gen 4...
