1 - 12 of 12 Posts
Was looking for a mount for my S4.
Here's what I found.....
Rokform "universal" Bike Stem mount
Attached to stem with a expanding well nut.
phone snaps on is sturdy and can quickly be
taken off.
Nice part is can loosen stem bolt and move
to other bike in like a minute.
going to try harry's lap timer with external GPS
Harry's lap timer can also remotely control multiple go pros
and record vid directly to phone and overlay stats on to vid.
Thought I'd share, hard to figure mounts and have not seen
this one before. Looks like it's going to work pretty good.
as cool as those mounts are, you gotta hide that radar detector and run leds for it instead! so much clutter up there! i made a mount and its attached under my front fairing above my fender. works great. leds on gauge cluster. can get a wire custom made from ebay for yours for like 30 bucks. has a power led and an alert led. you can also get a kit that has wireless led for your helmet so you see it when not looking down. i wired mine in. i have a small wire i clip in on my jacket to helmet and from bottom of jacket to bike. its a hassle kinda and i only do it when i go for longer rides... otherwise i rely on gauge mounted leds.
  • Like
Reactions: Capncalyx
ZX-10R enthusiast
I'll take the clutter over exposing my radar to rocks and other things that could damage it. I'm actually very pleased with my setup. Would you post some pics of yours?
I have the HARD system installed in my helmet.
http://www.legalspeeding.com/HARD.htm
I think I know where 95 is talking about. On our Gen 2's we have a little area in between the headlights theres a black piece kind of like a "Shelf" if you will lol. I threw my Ballasts for the HID's there.
I love my Rokform fork clamp mount on my Gen4
I see you have the stem mount too.
Did you drill and tap the top triple? I thought about
drilling and tap the top triple, but if you get the
"Universal" bike stem mount instead of the "pro"
the arm uses 2 bolts and the arm is off centered so the base
fits under the damper.
Oh...I see there's a hole in the top triple, cool.
Nice set up though.
Where can I get this mount? I think it would be a good way to mount a lap timer and my phone.
I see it cleared the oem damper. How is the clearance when you move the bars left and right fully?
Discussion Starter #10
Yes, it did rub a little bit, so ground some of the base off
and now clears nicely, lock to lock.
So far pretty good. I've had on a couple of track days and
no issues. Also still like the fact that I can move to my other
2 bikes, about 1 minute to uninstall and reinstall.
There's a lot mounts, this one might not work for everyone
but has fit my needs perfectly.
Shop Mountable, Protective cases and Accessories for Apple iPhone and Samsung.
1 - 12 of 12 Posts
