1 - 6 of 6 Posts
Shoudl I get the LC-1, SSI-4, & PL-1 combo or the LM-2
I'll be doing tuning on my race bike. Any recommendations between the above choices? I'll be doing the data logging while racing/practicing. I want to be able to track RPM and TPS along with the AFR readings. From what I can tell, both cost about the same. Any reason I should choose one or the other????
Why not a Wego 3?
Heard the innovate one was better. Really just need a wideband setup that can datalog and output to a rpm/tps table so I can tune my ecu. Almost any one will work I suppose.
Id do the LC-1, SSI-4, & PL-1 combo for a permanent install. Are you running a Kawi race ECU?
Yes, I am running the race ECU.
1 - 6 of 6 Posts
