1 - 9 of 9 Posts
im really embarressed to asked this but i dont wanna mess up.well here it goes where do i connect the black starter cable to? the pos side ofthe battery or somewhere else? i was looking thru the manual and all that did was confuse me more! help please
black to negative (-) red to positive (+)
Connect positive first then negative.
Disconnect = negative first, positive second
Black to negative (-) the cables won't go far enough to reverse them.
________
EXTREME Q
sorry guys maybe i didnt explain it right.its one black cable coming from the starter motor.
Premium Member
The other end of the cable from the starter motor goes to the starter solenoid ...
Premium Member
Big relay-looking gizmo under the rider's seat, next to the battery, which also has another honkin big cable that goes to battery +, and the main 30-amp fuse on top, with a bunch of other smaller wires going in and out.
Premium Member
PS you really need to pay attention to which way the wires attach at the solenoid. The book explains it. Starter motor power is not fused, which means if you get it wrong, really bad things happen ...
thanks it makes tons of sense now that u say it. that was it. i feel soooo dumb! thanks for the help guys
1 - 9 of 9 Posts
