1 - 6 of 6 Posts
i have a ignition module installed on my 2006 zx10r. it has been installed for about 2 years with no problems. yesterday i was re setting some ignition figures and when i was done, the bike would start and run for about 5 seconds then stall. the red light just blinks on the module. the module is set back to zero values but the problem continues. i removed the module and the bike ran fine. i installed the module on my other 2006 zx10r with a different power commander and it also stalled after about 5 seconds.. i re installed firmware but it did not help. i have herd of this before, any ideas.
You call dynojet and tell them your pos im is broken and send it in for repairs!
BTW why were you changing your numbers?
i had the bike advanced 1-2 degrees because i was running VP mr12 fuel. i was going to switch back to VP u4.2 so i was putting in a different ignition map.
I gotcha brian... Yeah there are a few people that run into problems with their im. Hence the reason why i call them pieces of shit. One of my personal friends had to yank their module off like you did and send it in.BTW who tuned your bike?
well the head was ported, and had a\ performance valve job from Sal, at Ace Performance. i installed web cams. Sal has helped me with some set up advice, but i have done the tuning myself as far as fuel injection. like i said Sal gave me a starter map and some cam numbers. bike is tuned for the standing mile. that's all i really do with it. not a street bike.
everything about dynojet is junk,the multihub looks like clown shit!if i didnt already have some of the junk id own a bazzaz!
1 - 6 of 6 Posts
