1 - 6 of 6 Posts
when my bike is up to temp and idling at about 1000rmps the bike sounds like a car with a big cam in, it sounds like its hunting..
does anyone elses bike run like that?
I turned up the idle to about 1200rpms and it a little better but still up and down, up and down then it will go smooth for a few seconds then back to hunting :dontknow:
all of my 10's do it. I would think it's normal, I mean, out of all (6) 10's I've owned, they all did the same thing. Not sure about the 08+ cause I never had one of those.
after I took it to the dealership for my fouled plugs prob I got it back and they had turned down the idle to about 800 rpms.. is that were it should idle? kinda sounded like it was on the verge of stalling
Licensed Dist of HaterAde
I think the idle should be around 1,000 to 1,200 rpms or so 800 is way too low i would think.
Idle speed is ~1100 RPM, and yes it's not even. These engines are optimized to produce prodigious amounts of power at high RPM, not idle smoothly.
1 - 6 of 6 Posts
