Pretty simple to check throttle cable, just look at the butterflies wile you open and close the throttle.
The throttle bodies should be closed all the way when the throttle is released.
If not you will need to go back and inspect routing and adjustments.
Stock grips? make sure the grip is not interfering with the throttle tube closing all the way.
No need to mess with anything else until you have done this as you will only complicate the problem.
I removed the secondary throttle body plates and the RPM did not change at all.
How many hoses did you reconnect to your air box?
i reconnected 2 hoses. One large and one small. while i had the airbox off messed with the throttle and watched what happened. it looks like they are closed all the way, but like i said i can roll the throttle forward and the butterflies move prolly like 1/32 or even less closed. i wouldnt think that would be that large of a deal.
there are three hoses total, one is an airbox drain.
You should be able to loosen your throttle cables to the point the throttle bodies close all the way.
None of this rolling it closed.
Then adjust the two cables even to the point you have full throttle operation open and closed.
You would know if you messed with these.They operate off of voltage.They allow the ecu to know the throttle posistion from idle to full throtlle allowing proper fuel injector operation.There are two of them,main and sub.They can be adjusted.If you did not touch these then dont you can make the idle worse.
this might be the key here.....reconnected the larger of two hoses closest to battery which the other is the air box drain. i now have to look and see where the third is.
ok parts fihe only shows the breather hose. the larger hose that is closest to battery in the center of air box
The one in front of the air box goes to the valve cover unless you installed block off plates. (really no need as you can just block off the line and do the same thing).
the clear one lower left is a drain and i think you already found your large hose off the rear lower middle correct?
Yes, correct.
and btw i am sorry but i was thinking all this time you were working on a gen 3.
However i still think your problem of high idle is throttle cables one way or the other.
You can start the bike with the cables removed for that matter and the throttle body plates should be closed all the way.
remember to put everything you adjusted back to the stock position before you started.
i dont think i understand your statement.......what is the reason. does it have to do with the pilot air screw? i am a little slow sometimes, sorry for needing elaboratioin
Doesn't hurt to ask.
All i am saying is "if" changes were made with the idle adjustment screw and or the pilot air screw ( i take it this is the screw on the side of the throttle body) put them back to the stock settings and address the throttle cables then start the bike and see what the idle rpms are at.
if you go messing with several variables at once your not going to accomplish anything.
no i didnt mess with any adjusting screw, just the idle adjusting cable in the fashion i previously stated. tomorrow i am going to take it back apart and check some stuff out.
