1 - 10 of 10 Posts
I wanted to remove my rear pegs and did so today until I noticed the rear brake resevoir is supporting by the peg, so Im not sure what to do. I was wondering if anyone else can maybe explain what I can do. Pictures would be great so I can see what you guys did. Thanks for the help.
Gone Ridin'
You can actually remove it :)
I have seen a few that replaced the resevoir with just a short tube and cap (I am pretty sure I saw some pics on here too). There isn't much need for more fluid than that in the rear.
on my 06..
The rear peg on that side just acted as a guard.
It bolted on to the fau-heat shield,plastic guard for heat burn.
I looked at it abit before I removed both rear pegs myself.
Works fine,jiggles a little but the whole Damm bike jiggles a little!
thanks for the help, Ill try to bolt it to the peg holes.
mine just has the line plugged .. only prob i have found is everytime i hafta use the rear brakes fluid leaks out .. guess the line is wore out at the end from being rigged .. i am actually looking into finding a smaller res to put back on instead of that big huge three gallon thing they put on from the factory
Custom Powder Coater
heres a pic of mine i just bolted it to an existing whole, until i get time too work on a hidden set-up...
Discussion Starter #10
That what I was lookin for, thanks blackpearl.
I will try to do that to mine.
1 - 10 of 10 Posts
