This would have to be the most expensive piece of tubing Ive ever purchased View attachment 402914
Sent from my iPad using Tapatalk
I was pretty annoyed to find out I paid so much for a plug and a hose clamp because that tubing got thrown in the garbage after two weeks.The problem with HRC tubing is that it sweats brake fluid. It literally is semi-permeable tubing that lets the fluid seep out of microscopic pores in the tubing and it will continue to do so until it gets old and brittle and then doesn't work properly at all. Back when all the HRC bikes used it the first things a technician did when handling the bike would be to wipe the tubing with the rag they always had in their hands...
Most people don't realize it, but brake fluid reservoirs are vented which is how they get moisture into the hygroscopic brake fluid which in turn requires the fluid to be changed at regular intervals to retain its effectiveness. The water absorbed into the fluid can be turned into vapor with excessive heat and then you get the dreaded brake fade we have all experienced. When you use a kit like that with a solid plug it can create pressure issues and improper operation of the braking system if not maintained attentively. Granted the rear is generally used a lot less than the front, but it can certainly happen.
Tygon tubing is a much better choice for that type of reservoir.
...wish I could like this twice. I made my own out of some poly tubing I had lying around for anodizing stuff. I figured, "hey, works for sulfuric acid, sooo..." but it sweats exactly like LDH is talking about..... and the tubing is getting softer and softer as time goes on.The problem with HRC tubing is that it sweats brake fluid. It literally is semi-permeable tubing that lets the fluid seep out of microscopic pores in the tubing and it will continue to do so until it gets old and brittle and then doesn't work properly at all. Back when all the HRC bikes used it the first things a technician did when handling the bike would be to wipe the tubing with the rag they always had in their hands...
