1 - 2 of 2 Posts
So I recently bought a 2012 zx10r, and I'm trying to find out if it's been flashed or what to look for to find out if it has been. 🤔 I havent seen any sort of tuner, or anything. Usually they have a sticker put on the ECU? But I havent taken the bike apart to look. My bike does remember traction control settings when turned off/on. Does have a graves exhaust, and does shoot flames when decelerating
It depends. There's really no fool-proof way of doing that unless you download the firmware from it and compare it to the default version. If the ECU was mailed into somewhere, they usually put a sticker on it to identify that. If the previous owner did it themselves, they wouldn't put a sticker on it. :D The traction control will only retain the OFF state if it's been flashed. Set the TC to OFF, turn the ignition off and then back on. If the setting stays OFF, that's a good indication it's been reflashed. Otherwise, it will always default back to setting 1 or the other previous setting. It will never retain and start as OFF though unless it's been reflashed.
The exhaust and popping and flames on deceleration are meaningless when discussing the reflash and has nothing to do with it. But the Graves is nice! Cool! (y)
1 - 2 of 2 Posts
