Hi guys,
I have an electrical fault that causes my cluster to turn into a Christmas light show and one of my theories is a faulty wiring harness.
How hard would it be to swap out a harness with an identical one? I'm wary because I've had my airbox off a few times for a valve adjustment, ECU flash, plug replacement etc. and noticed that the harness is crammed in pretty tightly around the head.
I have another valve adjustment coming up as well as a radiator flush so it would be a pretty good time to tackle a harness swap.
Any tips, tricks or insight into a swap is much appreciated! FYI, I have an ABS model with the mechatronic steering damper.
Cheers
Cheers
