If you do wheelies with the ZX-10R, you WILL break your air tube. It is inevitable. It doesn't matter how good of a rider you are, or how easy you put the front end down. It is a terrible design from the factory. Do a search on this forum, and you can see many examples of folks that have had the air tube break. There are also many examples of how to fix it.
When my air tube broke, I read the forum to see what other folks did, and to see if I could find a carbon fiber one. It was suggested that you could get a carbon one from this site: http://www.rhencullen.net/acatalog/Online_Catalogue_Carbon_fibre_693.html
Well, I DID order one from that site - over a month ago. Still no carbon fiber ram air tube. At this point I guess I can kiss my $200 goodbye from rhencullen.net. I might get lucky and it might show up someday from Europe, but the weather is changing and I can't wait anymore.
So I ordered a replacement OEM ram air tube. $90. What a ripoff. I got it knowing that I would figure out a way to reinforce it.
Two days later, the stock OEM ram air tube arrives, and I started to look at it for ways to reinforce it. There was one thread from "swade" on the forum who built this solution:
This is a nice solution, but it isn't what I was looking for because:
Another user, "10 Speed" made this solution:
This looked like a stronger solution, but:
Here is a side picture of my solution:
Here is how I did it:
Now I can ride wheelies without worry. Except for the cops.
- it puts sheetmetal into the air tract
- it is done by drilling holes into the plastic
- It puts the poprivets into the hole
- It isn't very strong
- it wasn't attractive
- it was steel, so it was heavy
- it was steel, so it will rust
- it wasn't elegantly simple
- Go to Lowes Home Improvement store, buy a 3 foot length of aluminum trim material. Its about 3/32" thick, and about 1/2 " wide.
- I used a piece of cardboard to both measure both the length, and where the twist point should be. Note that the piece should twist over the ram air tube in opposite directions on both sides. I used a sharpie marker to mark where the twist points should be on the aluminum.
- To twist the aluminum, I simply used two adjustable crescent wrenches and twisted with my hands. Easy.
- I recommend that you drill only one hole, then bolt it up, so that you get the piece lined up perfectly before you mark the second drill hole.
- Drill the holes with a 1/4" drill bit that can drill through metal.
- The stock frame bolts will not work, because they are not long enough to go through the aluminum and the frame. I had some spare bolts that were a little longer. You can see the difference in the side view if you look at the top bolt, and the bottom bolt. The bottom bolt is stock and doesn't need to be changed.
- No special tools, no welding
- No rivets or drilling of the ram air tube
- No plastiweld
- Material is inexpensive ($3)
- Will not rust
- You can paint it
- Quick - I made both pieces and installed them in under an hour
- Lightweight - the pieces are very light
- Nothing is placed inside of the ram air tube
- Small but strong - You only need to bolt to the top hole to prevent air tube breakage. The air tube tries to lever out of the frame, putting the majority of the stress on the top two air tube tabs. Connecting the gauge bracket to the frame directly using this method makes the tube and the upper VERY strong.
