1 - 10 of 10 Posts
anyone have a how to on replacing fork seals and what is needed. Thanks for the help in advance.
Chickenstrip Eater
Take it to a good shop unless you have or want to invest in special, job specific tools. Believe me. I learned the hard way.
I read a lot of other posts that said you didnt need the tools. I could have miss read it but that is basically what every fork seal thread is on.
Chickenstrip Eater
OK. I'm trying to save you some frustration and damaged parts. Do any of those threads give a how to? Doubt it.You'll need a seal driver which ya can improvise and you'll need a cartridge fork tool which is a very necesary tool that's not easily duplicated with duct tape and bailing wire.
Dido, not worth the frustration. This is one job, that unless you have the right tools, don't attempt. A decent shop will charge you under $200.00 to replace the seals. Not bad really. Buy the type/kind of seals you want and take to shop. Parts are cheap at least. Labor is the only real cost. Peace :cool:
Retired post whore
:+1:
Ok Calvin. I'll give you the answer you want to hear...
To do your fork seals you are going to NEED about $200 worth of special tools. That is a fact. you are also going to NEED about $25-$35 worth of parts. You are also going to NEED a copy of the shop manual.
I just had my seals redone a couple of months ago. I took the forks OFF THE BIKE and took them in, where they sat behind the parts counter for nearly 2 weeks before they shop guys got around to them. So 2 weeks and i think $250 later, I had my fork seals replaced, and my fork caps fucked up where they opened them with a crescent wrench or Gator-grip or some damn thing.... That will not happen again.
Next time, I will order $250 worth of parts and tools and do the damn seals myself, not have to wait on a shop, know they are done right, and have new tools AND new seals when i am done. So the NEXT time I need them done, I will only have to pay for the seals.... you follow me?
NO it's not a hard job to do.....IF you have the right tools and you are mechanically inclined and can follow directions. If this does not describe you... I would just take it to the shop.
You can do it with out special tools.... There is a way, I do them in my garage with just standard tools....
But if your not a mechanic I would suggest taking them some where, even the way I do them may be a little difficult if your not really careful at what your doing....
There is a few short cuts you can take and it makes it simple, well I think so, but i'm a mechanic.... Every time I try to explain something, people say its to difficult.... :dontknow:
Discussion Starter #10
Heres the thing. I went to a kawi shop and asked them they said $230 PLUS parts. So i figure if i spend 150-200 on the tools and get it done myself when one of my friends need theres done i could help them out for a small fee. I actually thought of just buying a secound set of forks off ebay as the pair i was biiding on went for $180 shipped so. I guess i will just look around and see if i can find someone to do it a little cheaper.
1 - 10 of 10 Posts
