1 - 20 of 21 Posts
Moved to Performance and Tech....do I hear a Yeah to copy to the "How To" section?
thanks, i know this is a simple mod BUT im sure their is someone who could find some use from this ;)
Doing this today. Gonna have my buddy hold the gas tank up while i swap the filter so no removing the hoses...damn i'm lazy.
Update : Did it w/o removing gas tank and w/no help. Just turn the gas tank around and rest it on the bike with a towel to avoid scratches.
lol i always take off the gas tank so i can anal clean all the shit no one see's. does anyone else do that???
edit: when is someone going to move this to the "how-to" section???
yeah the link you posted just takes me back to this thread.
Hey, great 'how to'. Wish I would've found this before i requested one :/
can the tank just be held up by another person while the filter is changed so I don't have to disconnect wires and such? does holding it up create enough room to make the switch of filters?
Licensed Dist of HaterAde
Does the tank have to be completely empty? Any good way to empty it other than letting it run out?
No drainage needed bud, just unhook the gas line and vacuum hose. Maybe put a rag or shop towel underneath in case a little go go juice spills when you first unhook the line but other than that it's fairly simple and straight forward.You can probably do it by simply propping the tank up as well (I have done this on my 1st gen) but its alot easier to justy pull the tank off.
1 - 20 of 21 Posts
