1 - 20 of 57 Posts
First, you have to open up the garage door opener (gdo) and find the switch. Solder on a wire on each side of the switch and close up the gdo body. I cut the plastic away a bit to allow the wires to go through the body easier. (there are no pics for this since I figure this part depends on what gdo you have)
Next, locate where you want the gdo. I put mine under the seat.
Now, run the wire through the frame and fairing to wherever you want the switch. I used thin speaker wire (cant remember the exact guage) because it's easy to route and is not very heavy:
Next is the switch. I didnt want to hack into my controls, so I made a bracket out of mild steel, drilled and painted it and mounted the switch from Radio Shack (p/n 275-644) on it to complete the install.
Now I dont have to fumble around trying to find the button through my jacket.
Great idea!!
man, i just zip-tied my opener behind the seat panel so i can reach it through the openings in the fairing. but thats trick, man. nice job.
Discussion Starter #8
Thanks.
I didnt want to chance screwing up the lap timer switch. You never know what else it would screw up. I'm not the best with a soldering iron, so one slip could have cost a lot.
:rolleyes:
did mine by
1 using a small wire to short out the the button on the opener.
2 My opener runs on a 12v battery (which I tossed)
3 then I soldered wires to the battery contacts on the opener....
4 Tapped the positive wire to the horn + wire and ground the negative behind fairing stay bolt
5 glued the opener out of site
6 honk the horn... the garage opens....or closes
*** you can also tap into you head light high beams ..but I ride with them on during the day. ... not sure how much juice goes through the lap times switch but you could try that....
Benefits:
1 The horn only works when the key is in... and so does the opener... leaving bike outside is only a threat to the bike not easy access into my garage which is attached to my house.
2 never need to change the battery on the remote, Install it and forget it!
Unless the bike gets stolen from the front of your house, then they have access to your garage when they undo the garage opener.
1 - they have to know I have it...
2 - they have to find where I cleaverly hid it.
3 - if they are that commited to getting into my house I'm sure they can find an easier way (alarms, locks, codes and such only keep the honest people out)
1- If they stole your bike, they will part it out which leads to
2- they WILL find it
3- they won't have to be committed to get into your garage and steal whatever else is in there when they have your garage door opener.
I always keep my bike in the garage so it will have to be stolen on the street because my german shep. loves to sleep next to it. :mrgreen:
but lets say it's stolen in the street:
1. I carry my registration in my wallet so there is no address to go and open the garage door.
2. My garage door unit enables me to re-program with my other garage openers which will disable the stolen one in the first place.
that's awesome! and I have the same cheap garage opener. but I also like the hardwired/no battery thing and that it's wired into an existing button I never use (the horn) but my neighbors in the apartment complex wouldn't like the horn every day..
Still here
I was thinking the same thing, love Kenny's hookup and no batt to replace, mine is 12vt too.
It is a small one velcroed where I can reach it for now.
Don't want to use horn button, thought blinker -but you'd have to cancel at one flash and may screw up the blink rate.
Maybe rear brake light switch would be an idea.?:dontknow:
Or just add a switch like the one in the original post and put it in-line of a 12volt fused lead to battery and ground the thing where ever or just run a ground to batt as well..
1 - 20 of 57 Posts
