1 - 12 of 12 Posts
First remove left side fairing(s)-
Remove counter shaft cover-
Remove counter shaft sprocket-
Drain oil-
Drain coolent-
At this point you can losen hose clamps on the two big radiator hoses-
Pull them off the cooler housing-
Remove coolent pump cover-
Remove coolent pump- (takes a bit of back and forth weezing)
Remove Bearing "housing"cover (also takes a bit of patience and back and forth movement)
Replace with new "bearing housing" cover
Repeat above steps in reverse order....
I put this up so's the next poor sap (like me) that this happens to, dosent have to pay a mechanic or shop 400.00$ in labor to have this done.
pics below....
its ended up costing about 325.00 in parts.
thats not including the oil to be replaced or the coolent.
or my friggin time.
it says-
EK520MVX on one side and Japan on the next link
AND- another thing I was just looking at the chain and I found ANOTHER link half way around the chain,from the break starting to tear away also!!
Ya, I think if you're regulalry hammering the bike you need at least a 525.
I'm in the clear there (installed ERV2 last summer), as I don't get much space to wind it out.
1 - 12 of 12 Posts
