1) Remove your puny little battery
2) Get your Dremel
3) Cut this little plastic divider out of the battery box (careful not to cut any wires)
4) Now you can fit a YTZ10S battery or equivalent size battery (preferably Lithium) for much higher CCAs (Cold Cranking Amps), and your bike will no longer start lazily and make you worry that it won't fire up.
2) Get your Dremel
