1 - 2 of 2 Posts
Did these today and decided to do a how to. I took as many pictures as possible to make it really easy to follow. Hopefully someone can use this or encourage someone to do their own install and save some money on labor.
1. Remove side panels
2. Remove the seat
3. Remove the top bolt on the tank
4. Prop the tank and disconnect the the fuel pump and gas line
5. Disconnect the bottom bolt on the gas tank
6. Remove the gas tank and place it in a safe place
7. Locate the gray plug on the left side and unplug them
8. Remove the white covers on both sides with a small screwdriver
9. Push the two middle, centered pins out on both connectors
10. Plug the wires in the new connectors
11. Put the white plastic covers back on the gray plug
12. Plug the gray connector back together
13. Run the red wire to the positive battery terminal
14. Plug the GIPRO to the two connectors
15. Route the unit to the dash and run the wire for a clean install
16. Program if needed
17. Pat yourself on your back and go for a ride
:thumbsup:
Discussion Starter #2
2. Remove the seat
:thumbsup:
1 - 2 of 2 Posts
