1 - 14 of 14 Posts
I had a Power Commander III on a 05 ZX10R. The unit went bad after almost 2 years. A co worker of mine also had his go bad on a FZ6. :dontknow: Have any of you had or heard of a problem? My local shop says for control units,Dynojet PC's go down the most. Even thou they sell alot of them.
This isn't sounding good now is it?
I wonder, out of the units that went bad, how many didn't have adiquate air flow. Maybe a tool plug kit on top of the unit makes them over heat? Vibration? Lot of money to last only 24 months!
La Flama Blanca
I have never heard on one actually going bad, I have ran them on three different bikes and never had an issue with them.
Wow, I'd really like to know because I may have to put a bag on mine to prevent getting wet/moist for my winter commute.
Retired post whore
I got mine second hand off fleabay and haven't had a single problem other than being a complete retard when it comes to downloading maps. :badteeth:
:+1: I've never heard of or had any issues.
The Power Commander is one the better units out there.We install 2 to 3 of these a month.So even on the low side that's 24 a year.
Only had 3 bad in 3 years.2 were installed by the customer and mounted in a bad spot.Guy with a TRX680 Rincon mounted it to the frame right above the exhaust.Melted the bottom of it.Another gentleman with a R6 mounted it in the tail section,but against the frame in a high vibration area.Last one on a YFM700 Rator just when bad.
Mounting location is very important!
Speed Freak
in the past 2 years at the shop i was working at I saw about 3-4 go bad but dynojet is real good about fixing things.....
I have their PC3, ign module, hub, and quick shifter and they are all working fantastic
I never had one go bad but have worked on some bikes that are bound to have them go bad. Water and dirt and dust and all that mojo all over it. I think its important to secure it down good too.
I only bought a Power Commander when I first got my bike. It was bad out of the Box. The company replaced it no Problem even though I bought from a non distributor....now that's service. I only have a slip-on so ended up selling it on ebay I believe so don't have one....plus I liked beating bikes that have one as well against my stock bike. :crackup::mrgreen:
even though I'm serious I'm sure I would like it with the slip-on and a custom map just never became a priority for me :badteeth::dontknow:
Discussion Starter #13
I mounted mine under the seat where the servo for the exh. buterfly valve was. Service manager said more Dyno jet units go bad than any other, BUT they also sell the most units by far. He would put another one on his bike, that is what he told me.
Almost two years for me and no problems at all. Just make sure your using the right maps for your set up.:thumbsup:
1 - 14 of 14 Posts
