1 - 20 of 37 Posts
The Movie Goer!
Before I get beat down with the search bat! I honestly did a search an couldn't find anything? But I wanted to know is there any way possible to take this piece off without removing the whole tail section?:dontknow: Thanx for any suggestions you guys can give! :thumbsup:
MIA Post Whore
which piece? The left mid pipe? The exhuast valve body/riser pipe? ...???
The Movie Goer!
That rusty clamp thing.....whatever it's called?:dontknow:
Looks like you should be able to although I don't have a 2nd gen so i don't know 100%. Looks very similar to one of those squeeze clamps where you can grab it with some needle nose vice grips and slide it up towards the rear?!?!?!
The Movie Goer!
Damn so I have to take the pipes off?:dontknow:
remove the left bolt on. remove the mid pipe. Tap it off with a mallet.
The Movie Goer!
Discussion Starter #10
No I wanted to take it off to get powdercoated black b/c that rust is bothering me! Can I take it off permanently? Do I need it? What purpose does it serve?:dontknow:
Are you removing it completely/permanently? If so you could probably be very careful with a dremmel and cut it off.
The Movie Goer!
Discussion Starter #12
Is mine the only one rusting like that? ::badteeth: Anybody else experiencing this?:dontknow:
The Movie Goer!
Discussion Starter #13
I never worked on that 2nd Gen Kawi but from what I can tell looking at picture I kindly suggest YOU DONT REMOVE the thing permanently!
It's clearly a clamp that keeps the two pipes together there where it develops a LOTS of pressure (and heat) when youre twisting throttle to damn hell.
No great danger, but without it you may:
A) melt some plastic stuff around it (do I see a mudflap in that pic?)
B) loose some little performance because of not correct pressure into muflers
The Movie Goer!
Discussion Starter #15
Where do you see a mudflap?:dontknow:
The Movie Goer!
Discussion Starter #16
Ok I finally got it! Had to take the rear tail half way off to remove the left canister to get that little rusty beeeeeiotch off! :headshake
MIA Post Whore
exactly what I suggested. Never meant anyone to think remove perm.
The Movie Goer!
Discussion Starter #20
1 - 20 of 37 Posts
