1 - 6 of 6 Posts
Title says it all really, I'vehad no luck searching. I can obviously undi the two top bolts on each side but then how is it still held in place?
Discussion Starter · #4 ·
Thanks I saw those rivet like things but wasn't sure what I'm meant to do with them
· Dont mess wit White Ninja
Four bolts up on top of the sub-frame holding your side fairings on and then the little piece too. There is another by your tail light thats attached to the subframe...Last there are two plastic rivets up under the tail...if anything it should take no longer then 15-20 minutes to change out your undertail...pm if you need help
Discussion Starter · #6 ·
Ok will have another look tomorrow, basically just need to get the right side off to install R&G tail tidy with Oxford Nano indicators :)
1 - 6 of 6 Posts
