1 - 20 of 34 Posts
Vitals 05 ZX10R 20K miles with mods in signature...While out on a ride today the bike started to develop a noise and some performance issues. Some minor surging at cruise 70 in 6th. It sounds kind of like my car did when it was running with one of the spark plugs out of the hole. The noise seems to be coming from the top of the motor. Valve adjustment done at 13K. I limped it home. Oil looks fine and radiator overflow looks fine. No FI lights and the engine temp [email protected]
I'm guessing valve issues?
check your spark plugs, that would be a good start.I had a plug go out on me a couple of weeks ago and it sounded like the bike was blown up. Almost like I dropped a valve or something. But i would check that and your wiring conections to be safe. I have heard of the PCIII causing issues too. Start simple and work your way up
i wish you the best of luck man...id pull the p.c and start checking the valves/plugs
Licensed Dist of HaterAde
:+1:..that's what i was thinking too. a fouled plug will make the bike run like shit and sound horrible. could be the PC as well BUT i don't know if the PC was going bad that it would cause any engine noise? best of luck though man, sounds like she's well taken care of which is a good thing. hopefully something minor.
I'll take a look when I get the chance and update...Plugs were changed 7K ago but I'll check them out.
I went ahead and changed the plugs since I needed to inspect them...That was a fun 3 hour job. Anyways Bike is still not running right. It almost seems as if the timing isn't quite right but it's going to go to the shop.
Discussion Starter #8
Bike is going in the shop tomorrow or Saturday depending on which day I can get it over.
Well the motor is torn down and the verdict is...I got somewhat lucky but it's still gonna cost me. This motor was not regularly redlined and only hit the limiter once on accel. It didn't drop a valve but was very close. Anyways some valve damage, 3 broken retainers, 3 damaged valve springs and 3 damaged buckets all on the intake side. Work to be performed and much of this is preventive maint.
1. tensioner
2. Head gasket
3 replace 8 intake valves
4. replace 3 valve springs
5. replace 16 valve guide seals
6. replace all retainers
7. replace all valve keepers
8. replace 3 intake buckets
9. shims
10. Cryo treat all parts
1. tensioner
2. Head gasket
9. shims
Ouch. Well when you get it back it will probably feel like brand new.
Discussion Starter #13
Valve spring retainers failed. OEM parts are going in but are being cryogenic treated.
HOLY CRAP! And you say the cylinder didn't get damaged? What about the cylinder walls & the heads? Got any more pics?
Guilty by association
im betting if its not the spark plugs its the valves
I posted all pics on my profile page. And Quick, what do you expect the cryo treatment to do for you?
Discussion Starter #19
It will harden the parts and reduce wear therefore prolonging life. They expect it will be better than factory and will never have problems again. I also found out that they are treating the exhaust side as well.
Are you concerned at all with the parts becoming brittle? Retainers see more stress than wear. Even valves, which see tons of impact stress, have annealed (softened) areas to prevent them from snapping in two.
1 - 20 of 34 Posts
