1 - 14 of 14 Posts
Well, I got 6 laps of practice in Saturday. On the 6th lap, the oil filter backed out a half turn and blew its seal. Apparently it wasn't properly safety wired. I didn't know there was oil on the tire at the entrance of turn 1.
If you watch this
video to the end, you'll see me enter turn 1 at about 147mph which was about the speed I was doing when the bike went full sideway right when I turned it in.
I thought I was gone. I thought I was on high-side trip to the moon. As gently as I could, I picked up the throttle and picked up the bike. Surprisingly the bike came back real gentle and it didn't even pop me up out of the seat.
I thought I had the problem handled so I rolled off and turned in again. Again, the bike whet sideways but quick. Again, a little throttle and pick the bike up. Now I'm heading off track, through the grass, across an access road, through more grass, and directly on to the steep banking. I managed to get the bike slowed down enough to turn it. I got it completely off track and stopped.
The engine was fine, I was fine, the rear tire was covered in oil and thrown away. We cleaned the bike, put a new oil filter in and safety wired it real good.
On Sunday it was 47f degrees when we took to the track for first practice at 8am and it was just a shakedown run. Jeff Wood wanted to prove that we Florida boys were wusses for thinking it was cold and threw down a 1:26. Next fastest was Dwyer at 1:30. Yeah, that woke us up!
My first race, GTO, was at 9:30 and 50f. I wheelied off the start and lost some time there. I then worked on hitting my reference points and getting up to speed. I was mostly in the 1:32 range for laptimes with two 1:31s. My personal best is a 29. The winner was doing 26s and the track record is 23.8. So the track was a bit slick but I've really got to work out why I'm 6-7 seconds off at this track and only this track. I made three passes and finished 7th of 14.
Next race was at 12:30, Unlimited Supersport, and a warm 57f. I was doing better, consistent 31s but so was everyone else. On the last lap, I was running in 8th and about to lap an amateur when I used a bit too much front brake and lowsided on the entrance of turn 4 at about 50mph. 15th of 15.
Next race was at about 2:30, Unlimited Superbike. I just wasn't in it. I was on the same front tire and I just didn't trust it at all. I was running 1:34 laps and was going backwards. I finished 10th of 11.
When I got back to the pits we found a small hole in the engine cover that was leaking oil, damage from my crash. We could have fixed it but it was time to call it a day. I did not start my last race, Unlimited GP. Apparently there was a red flag on the warm up lap for that race and only 7 finishers.
Next it's on to Daytona February 27th and 28th.
What front tire were you running and how much air were you using? Maybe looking back you could have switched it or dropped a lb or two in the front. Still a race well done
hey greg dont sweat it.that wood is fast as hell at that track. i was at the school on friday and the dude was pinnin it to the rev-limiter into turn one.It was 72 degrees at the time.i think he ran into the 1.25s and wasnt even trying,That guys fast but i gotta tell ya,you didnt look slow at all on youre run.good luck this year and maybe ill see you at palm beach.
Keep your chin up Greg and best of luck to you at Daytona. Be sure and post up your results. Im pullin for ya Bro'!
Greg hope you had a blast . Having fun is what its all about . Due to the weather here in phila. , we didnt make the race but we will be at next round . LOok for Team NASBIKE . Stop in for a cold beer or if you need any help . Take care Jake
Thanks guys.
Tazman, I was running a medium/hard front that probably wasn't in its temperature range on the right side since there's only 4 right turns at Homestead. I was running a 1lb low on it.
Here's the video my wife got of my crash in turn 4.
youll getem next time.
Greg Who makes a dual compound front tire ? I use Dunlop and Pirelli and I asked if they make a dual compound front but they sid they only make them for the rear.
Oh technically it's a triple compound. Really, it should be medium/hard/medium.
Take a look here and look at the 209GP FT/211GP Rear special. Also, this page shows more (not all) compounds, http://www.dunlopracing.com/fitment.htm.
Thanks Greg I DO have the same tires .. The rep must have just used the middle compound as the type. I was serious about stopping over for a beer lol. Ive never actually me a person from a forum and as a fellow racer helping out is our pleasure if at all possible . We just got new magneseum rims that are 65/8 or 3/4 ?Rear . Thinking or going with Pirrelli now that we can mount a 195 in the rear . the bike has ALOT of hpand torque comming in at 3000rpm and 190 pirellis sidewalls distorted( due to acceration from torque . They say the 195 Pirelli has thicker/stronger sidewalls than the 190. Dunlop 190 sidewalls are stronger . Rider says Pirelli tires are stickier , but I cant tell the differance. CAN YOU ? I might be biased having 2 new Pirelli front tires split down the center down to the cords at 80 and 85 mph . Bought the 2 sets of Pirelli tires 3 years apart, only trusted second set because i figured after 3 years they had problem fixed .
Discussion Starter #11
I haven't ridden Pirelli in a long time, years, so I can't comment on their current state. I can say I usually use a 200/55 DOT rear instead of the 190/50. Two reason, 1. It's the same diameter as the 195/65 slick and 2. it has phenomenal side grip.
I don't understand the rim measurments 65/8? What does that mean?
Greg excuse my legendary horrible typing/spelling ( big hands and board is gettting wore out ) The rim measurement is 6 5/8 inches or 6 3/4 inches . I wasnt alone in disliking Pirelli tires years ago , they where expencive and you where paying for the name ... After Metzler tire from Germany bought Pirelli they became the good quality tire they are today in Motorcycle Tires . As far as Pirelli car tires are conserned , i have never owned a set and cannot comment .
I wonder why that tire dimention change gives more grip for you? GREG do you loose drive grip with the 200/55 tire dimention ? ( meaning do you get wheelspin ) Our Bikes strenth is its tremendose drive off the corners so that is important to us . Thanks for the info , we will try that tire size ourselves .
Discussion Starter #13
The 200 is just better all around for me in side and drive grip. Yeah, it'll spin up, but then any tire will. It just doesn't do it as easily as the 190 does.
1 - 14 of 14 Posts
