The name fits the finish – The Terror has one of the gnarliest paint schemes we’ve seen from HJC helmets and will get you compliments all the time. If you’re not already familiar with the FS-15, it’s the same model Ben Spies used in his World Superbike Championship bid. There’s plenty of ventilation and it’s quite comfortable for a helmet in this price range. The interior liner is designed to wick—up moisture, keeping your head cool on hotter days. It’s also fully removable so you can freshen it up every now and again with a little soap and water. The Pinlock-ready visor can be exchanged without tools and has an anti-UV treatment so your face won’t turn into an orange peel after a day on the road.
For the fastest service, ring TJ at 866.931.6644 ext 817. You can also email him – send those to FORUM at RIDERSDISCOUNT dot COM with HJC TERROR in the subject line and be sure to include what size you’d like. If you’re unsure of the size you need, just let TJ know what you currently wear and let his experience get you fitted for the right helmet.
