1 - 6 of 6 Posts
I cant stop my frontend from wobbling after about 130 mph I just had the tire balanced and the front tire is almost brand new has anyonelse had this problem
Need a little more info
Whats the tire PSI your running? Have you adjusted your suspension any?
If tire pressure is good, and you haven't changed the suspension,
then check your head bearing....or just relax your deathgrip on the clip-ons?:dontknow:
And you said you had a almost new tire, did you have this problem before you changed the tire?
I had the same problem, had the wheel ballanced three times. Finally the mechanic noticed something on the third ballance. The tire was not a perfect circle. There was a slight lump in the tire that you not see unless you had the bike up on stands and turn the wheel. Try that and see if thats the problem.
1 - 6 of 6 Posts
