1 - 4 of 4 Posts
Hi all,
Can anyone recommend a high quality racing fork oil for Showa Big Piston Forks?
Also what is the weight of the standard oil.
It'd be good to hear from those that have found improvements running different weight oil, as I may do the same in future.
Thanks.
I used Repsol 5W oil, and the bushings that slide used K tech ones... as a improvement...
just one more click in compression...
I used Repsol because is free for me...
Discussion Starter · #4 ·
Cheers for the info...I can get Motul Factory Line fairly cheap so going for that.
1 - 4 of 4 Posts
