1 - 20 of 121 Posts
Guys, if your in the high 9's low 10's post up...and your bike combos / weight of rider too...
Thanks all.....
Shorty's Performance
My friend and team mate goes 10.0s all day long! Stock wheelbase, D&D slip on, -1 in the front, lowered an inch in the front and strapped down and no air filter.
Why not...I'm just getting back into bikes, 6 or so year break...and I'm a huge 1/4 mile fan....(03 cobra racer)...and I want to see what skilled riders are doing with these bikes with certain mods, or lack there of.
Thanks for your great post...:thumbsup:
i know most of the bikes will do mid 10's stock. do some gearing and full system exhaust and maybe a power commander and you will be in the high 9's.
03 cobra's are awesome by the way. great for track and play
10.2's/142 @ 3200+ ft deset eleveation: -1 in the front, PC3, and 190-ish suited. Thassit for mods at the time. :)
these bikes really fly....whats all of your 60 foot times???? 1.7's???
Discussion Starter #11
dang it man...thats rolling out...stock clutch??? and I see your running a shinko...very nice man...your driving the hell out of it for sure....how many passes on the stock clutch??
Thanks. Stock clutch and springs. (knocks on wood set-up continues to work)
I would say there is at least 30, if not more passes on it already.
I have a Cycle Concepts drag pack and stiffer springs waiting if/when this one decides to go away. (knocks on wood again)
I work weekends so the only track I can get to is an 1/8 miler. I'm 185 lbs. 05zx10. I'm runnin stock suspension height (no straps) and stock swing arm, foot shiftin, full tire pressure. Best 1/8 mile time of 6.76 @ 115mph. I'm sure that would equate too mid nines. I'm suckin most everybody up on the top end in third gear. ----slipon akro, bmc filter, power comm w/dyno tune. -1/+1 gearing.
Discussion Starter #14
10 havens..nice job and set-up..thanks for your imput.....and wildb302..hell ya your rolling out.... great job in the 1/8th......how are you leaving..??what rpm?? Everyone with slipper clutches..are you going back to a slipper clutch when your stocker checks out????
My clutch is bone stock. I'm leavin about 4500 without moving the throttle untill the clutch is almost all the way out. Sometimes the rear brakes loose a little and almost alwaays riding on the rear wheel only till I shift into third.
Moved to the Proper Section :heyyou:
:mrgreen:
Nope, you won't even Break into the 9s with that time and I run the same gearing.....you need to be at least around 6.5s. :wink:
Trap speed has alot to do with it. I'll have to get to a 1/4 and find out. I've been drag racing something for bout 14 years now and I'm pretty sure that at that speed the second half of the 1/4 is going to take much less than half the time of the first 1/8, but hey I could be wrong. I look forward to trying when I get a chance. It would be close.
Here is mine and I weigh 215lbs in gear but have also even been questioned on this site(by members that did 9s stock) how could I pick up 30mph + on the back half....the answer is simple I am Fast on the Back Half so if you think you can do better than this on the back half and hit mid 9s than good luck. :spit:
Mods are not even as good as yours....Old 10R with just a slip-on, -1/+1 gearing, BMC street filter, 520conv, lowered in rear about 2-3in,strapped in front.....just strap your bike your times will go down your doing good but you wont hit mid 9s with that setup right now unless you got mad skills and weight advantage :headshake
I know for a fact I would pick up more mph than that! Your strapped so your hittin full throttle before me. I'm not hittin full throttle till past half of the 1/8th. almost in third gear at that point, then i really start movin. Plus I'm 30#s lighter than you.
1 - 20 of 121 Posts
