1 - 5 of 5 Posts
Ok so I know a thing or two about HID kits since I've had a bunch over the years. What I don't know, is how to get both high and low beam to be on at the same time and be able to use the stock high/low switch. As in, dual low and dual high? I know you can buy two H7 kits and you will have both at the same polarity, but does that make them also turn to highs? If you guys know of a kit can you give me a link also.. need this asap because my current kit broke.
Yeah i know its expensive...im pretty sure there's a writeup on the forum here how to do it
I just contacted bkmoto and they said the only way to have dual high/low is to change the projectors to dual high/low projectors since the stock ones are just a single high and a single low.
1 - 5 of 5 Posts
