Thank you zx racer for reply , I thought so to at first but it revs sitting at an idle, no rider! Riding with bars straight approaching a stop sign or set of lights the bike will just up and wanna go!!
Then it drops to normal. No set amount of time in between these hi rev times but it's enough to not ride safely. Was running premium gas ( m in Ontario Canada ) 91 octane is the highest.. I dropped my oil, filter and changed plugs NKG.
Filled it wit lower octane gas 87 and it ran beautiful it was fast , throttle spot on and even ran cooler...for two days then bang problem is back !!!
And now I'm at a lost ? I've read and inquired so much that I'm literally confused . Started thinking throttle positioning sensor but it doesn't go to a lower idle under 12000 -1000 and it doesn't stall so wouldn't it do that if it was tps?
I self diagnosed with jump wire on FI light and no code all good so.....I'm a down biker. Biker without a bike! Nothing worse
